Southwind 15-28
Guest
Post by Guest »
Sheetsrep
I show your account as active.
sheetsrep
Post by sheetsrep »
:oops: Sorry about that
sheetsrep wrote::oops: Sorry about that
:wink:
Re: Southwind 15-28
"Bump" :P
Tor
Re: Southwind 15-28
Post by Tor »
Here's a trick little question...
If the beam is narrower how much lower would you need to sit to maintain the same stability?
As some have commented my balance is reasonable and I do sit high, although I have lowered my sitting position now I venture onto sheltered bays and estuaries.
I like the idea of a narrower (assuming easier paddling/faster) Southwind even if there is a capacity trade off but if there is a significant lowering of the seat to keep stability I'd like to see a slight lowering of the sides to maintain the paddling ease and reduce the knuckle wear. However I have had a wave or two over the front deck when punching through small swell, which the coming kept out of the boat so I'd like to keep that "feature"...
I'd also suggest that the deck should come as a 2 piece rather than 3 for ease of construction.
and what about a "sit on" insert/seat thingy so that it was self bailing.
Please do something soon Mick has too much spare time
Tor
Re: Southwind 15-28
Mate, I think my SW 17.9 is 28 inches wide and it is as stable as a house. The seat height in mine is around 7 inches above the floor.
My personal preference should I ever build a smaller Southwind would be even narrowr, probably in the 24 to 26 inch range.I think the boat at 27 -28 inches would be very stable with the seat 3 or 4 inches off the bottom.
Tor
Re: Southwind 15-28
Post by Tor »
what about 24" beam with optional outriggers fot rougher conditions or for sailing.. (adventure island inspired)
Re: Southwind 15-28
15' X 24" would be a beautiful thing indeed. :D
