Tor;
Fitting something like Chuck did into a boat is not that hard. You need some tape, some index cards (or old playing cards), a piece of cardboard and maybe an extra set of hands.
Cut the cardboard to a shape that will fit where you want it. Doesn't have to be a perfect fit, a oval in a trapezoidal area would work.
Put a index card against the inside surface of the boat and tape to the cardboard piece you cut earlier. Then repeat, overlapping the index cards and tapping to the cardboard.
When the index cards follow the inside surface of the boat all the way around. Remove the whole thing and use it as a template to trace on to a piece of wood. Then cut that out and install in your boat.
BTW, your boat is looking magnificent mate - as usual.
Mick...
Thanks for the complement , if the truth was known , I'm only getting lucky on this build and the boat is basically putting itself together. To darn hot around here during most of the day so this is a slow build. Spend a little time on it , go inside and cool down then do some more the next day.
Trying to figure out the steps ( basically on how to make sure they stay light in weight but strong in the strength ) before proceeding onward and upward.
Right now with the seat in it and the inside 99% done .... She weighs 21 pounds , according to my bathroom scale. (I have the two thwarts to instail later today , they might weigh a pound , together ).
Well the inside is done ( except for some minor cosmetic things ) , time to flip her over and start on the outside.
Some hull saturation , filleting seams , filleting the ends , sanding , glassing , graphite mix then lots of sanding and varnishing the outside and inside.
Final step , getting her wet and I sure hope she floats.
Pine lattice or screen molding , 3/4 inch by 1/4 inch and 16 feet in length , trimmed to fit the canoe. Same on the inside but the spacers on the inside are redwood strips cut at 2 1/2 x 3/4 inches.
Epoxy does a nice job as a light stain.
