Finally started - Boat shelves and Pirogue
Re: Finally started - Boat shelves and Pirogue
Worth looking into, although I haven't come across it in my enquiries at marine suppliers.
- Type of boat I like: Okwata.
Getting very close to painting the inside. Is an undercoat needed if I use an acrylic/latex waterbased porch paint? The local paint guy, who knows his stuff paint wise but not boat wise, recommended I use one.
Simon
Finished the second graphite coat on the bottom. One more coat in the morning should do it. Getting close now
Simon
I have put on the third coat of graphite and I am not sure if I have put enough graphite in it
. I can just see some of the grain of the wood in certain places, only just and you really have to look. Should I do another coat and this time add more graphite?
Simon
Thanks Matt.
I got the plans for the Merrimac today as well.
Hopefully it won't take me as long as this one.
Simon
Have a slight problem. I painted the inside of the hull with primer yesterday and in a few isolated spots it had some small cracks develop after it had dried. When I touched these spots it was very sticky like epoxy. So I scraped the primer back, sanded, and hit it with a bit of acetone before re-priming. All was good until I painted today and the same happened in the same spots, although to a lesser extent. Again I have scraped the paint back and sanded but have not re-coated it yet.
Any suggestions as to what I should do, or what may have caused it?
Simon
Maybe a little amine blush.
Did you get a good surface prep before priming?
Hi Matt - I thought I had prepared it pretty well. Didn't notice any amine blush at the time. I will try again and see what happens after another good sand and scrub.jem wrote:Maybe a little amine blush.
Simon
Finished painting the inside, no more issues after a bit more sanding in places. I have put the first coat of varnish on, with a few more to go. I am really excited to get it to this point and am really looking forward to putting it in the water
Even more exciting though is the thought of starting on the next one
Simon
