8-Harness Satin Weave
Post by Kayak Jack »
You're probably right, Chuck. If I weren't so lazy, I'd walk down to the basement and re-read the instruction manual. sigh I know that there is a big difference in convenience for the builder with loose weave, and I found inconvenience with tight weave. Could be the klutz-factor.
lncc63
Post by lncc63 »
We have only one weave. It looks like plain weave as best as I can tell. The thing I did notice which is probably true of loose weave is that threads get easily pulled causing irregular spacing. This particularly happens when the cloth is folded.
Has anyone had problems with these pulled threads?
Louis
I have. You have to be careful not to snag anything wile you're positioning the cloth.
Sand everything smooth.
lncc63
Post by lncc63 »
Hope you don't mind Matt, just so others aren't confused. I think you mean sand everything smooth BEFORE you position the glass so there is nothing to snag on.
Louis
lncc63 wrote:Hope you don't mind Matt, just so others aren't confused. I think you mean sand everything smooth BEFORE you position the glass so there is nothing to snag on.
yes, exactly.
Also be careful not to lay the glass on or around sharp tools like saws or chisels.
Sometimes, even rough skin on your fingers will snag the darned stuff too. It can be a real pain.
LEE SCHNEIDERMANN
re: wetting out the glass
Post by LEE SCHNEIDERMANN »
I haven't read all the way through this, so maybe someone has already posted this one. When wetting out a large area I make a frame up and stretch aluminum screen over the frame. Hold the screen down on your work piece and roll out the epoxy into the glass, through the screening. With a little practice and patience while you get the hang of it , it keeps the glass in place while wetting. When I finish an area I just lift the frame and move on to the next dry area. Once enough area has been wetted, you can move back over any dry spots without pulling the glass out of place.
Lee the "hairy-tick"
Forgot to mention, I only use bright aluminum screen for this, not the painted charcoal colored stuff or the fiberglass kind.
Post by Oldsparkey »
I start in the middle and work to then outside with a roller , never had a problem with the glass moving.
LEE SCHNEIDERMANN
Oldsparkey wrote:I start in the middle and work to then outside with a roller , never had a problem with the glass moving.
Yes but you don't live in the same sphere of mere mortals who look for the hard way to do EVERYTHING! :wink:
Wrong , if there is a hard way of doing it ..... Trust me I will try it. I like to contribute it to good luck or dumb luck .. your choice. Anyway I use all of it up building boats because I can't hit one number on the Lotto much less all six. :roll:
