I will be selling these separate. Dan mentioned they were a little tight in some spots. I'll have to get up with him to find out where they need opening up.
I'm pretty sure my placement measurements are OK. I'll check them again.
But what else could I be doing wrong?
Dan;
Are you wondering why the horizontal and vertical lines drawn on the first frame are not parallel with the ones drawn on the second frame (shown in your last photo)?
Just two panels stitched together is still pretty flimsy and twisty. The more panels you stitch together, the hull will become more stable & ridged and that twist will start to work itself out. Then it will me a matter of loosening & tightening stitches to get the last little bit of twist out.
But if that is not what you were questioning, please clarify.
Precisely my fear. I'll try adding a third, but it sure seems awful weird.
Manji
Matt provided it. Measures 7/16", but maybe it's metric.
Not in a position to mess around with drive at this time, but when I tack glued it for fit, anything that needed to be moved a bit was done easily using dremel.
Manji
I still don't quite grasp what you concern is. It's probably right in front of my face but I'm not seeing it. If you're worried the frame look a little crooked right now, that will take care of itself when you stitch on the other panels.
Can you reword? Maybe another pic with a pencil or stick pointing at the issue?
