Had trouble getting enough filler material to stay in place on the ends to allow for shaping so tried putting tape extending above line to support it.
Got there in the end.
Had the hull out in the sun for a while to help harden the last filler and the shadows showed up the pinched end curves in the panels. This shape is supposed to be good for improved tracking.
Now for the misery bit.
Made a bad decision last night. Was already tired and decided to go ahead with glassing the hull. To cut a long story short it was supposed to be the glass on tacky resin method but the resin had not gone off enough and it became a mess. Result is wrinkles along the bottom, resin
everywhere (took a while to get my knees unstuck from each other
) and today I bought a new pair of shoes. 'Nuff said.
The clear message for a first timer here is: follow the recommendations in the instructions ie apply the glass to a dry surface (if I had done this it would have conformed nicely and there would have been NO problem!) and get someone to help you if possible.
So that's all in the past now and I am starting from here.
Sides look to be OK although there is some excess resin in patches. The bottom wrinkles look like bubbles but all feel solid. The problem is that the glass is raised in these areas and will be prone to sanding damage.
There are 3 options that I can think of:
- Coarse sand it all off the bottom and reglass (don't want to)
- Carry on and sand carefully so as not to go through the glass (Will leave a rippled bottom). Use as is for a while with the option of applying another layer of glass during winter maintenance.
- Carry on by sanding the bottom and applying another layer of glass now on the bottom only. The glass is lightweight and I was thinking of doing this anyway.
Opinions/recommendations welcome.
