Was able to pull bow together fairly easily .
May not need your jig unless it's for alignment. See photo below. The thing is resting on all the twisted wires so it's off angle with the vertical -hard to tell yet. I'll check it with a plumb bob when I flip it.
I thought the stern snugged up good. The panels just overlap the lower transom.
Matt are you sure it's Ok to proceed without the upper transom part?Appears to be missing?
Mick Here they call the giant trevally "Ulua". That one was 36lbs although I did a tag & release on one a couple of weeks ago estimated 65 or so. Like lifting a cement block off the ocean floor.
