Prototype Bluefin 12; 12' fishing SOT
One of these days, I'm gong to have to climb onto one of these sit-on-tops. As of now, I'm not used to seeing a plywood mortar box inside a boat. I think, though, I'd really like the self-bailing feature.
The self-bailing is amazing. This fall I was out in our tandem SOT that Matt designed. We were fishing right on the edge of a shelf when a large ferry roared past and threw up 6' wave which broke on us because we were right on the shelf. While the kayak rode over most of the wave, the breaking aspect of the wave dumped into the cockpit. It was pretty near filled up. However, it emptied itself out completely in under 20 seconds. That was a very good test and it performed beautifully!
I managed to get a bit more work done. The cockpit exterior has just been glassed and two sets of hull panels have been stitched to the frame.
Cockpit exterior just glassed with one coat epoxy (it's still wet)
I decided to try making the foredeck out of one piece of plywood with a curved shape. Thought it might look nicer...we'll see if I succeed. Note the front cockpit wall is curved and has "ears".
Two sets of hull panels stitched to the frames
All the hull panels are now stitched (see photos below). I think I have a little twist in the stern area. I hope to straighten it out once I flip it and start filleting. Matt's bow jig is a stroke of genius for aligning the bow. I hope to fillet by the end of the weekend and install backing in the cockpit for foot-braces, hatches, etc.
All stitched up
Matt's ingenious bow jig
All stitched up
If the horses are level in relation to each other, you should be able to bully the twist out. Might need some straps or weights to hold it in place while the out hull fillets cure.
I'd take it off the horses, and try to twist the opposite direction. Use 2 people for this. Might have to over-compensate a bit to get it to where you want it. If it's stubborn, you might need to cut a few stitches loose.
I made some good progress this week. The hull has been fillet'd and a saturation coat applied. I also pre-staged the area for my depth sounder. I cut the area out of the hull and filled it with an epoxy/collidial silica mix. The folks at West Systems tell me the depth sounder can shoot thru it. This way I can fiberglass right over it. See photos below. I hope to glass the hull exterior this weekend.
1. Hull fillet'd
2. Hole cut in hull for depth sounder and covered with plastic sheet and packing tape on exterior.
3. I beveled the interior side of the hole so the epoxy/silica had something to grab onto.
4. Depth sounder hole filled with epoxy/silica (interior view).
5. View from exterior of the depth sounder hole cured after removing tape/plastic and sanding.
6. Hull after saturation coat (note white spot slightly forward of midships for depth sounder)
1. Hull fillet'd
She is looking good , really good.
It is always a pleasure to see a hand crafted boat coming together and looking so nice. The grain of the wood sure stands out and you will have one beautiful boat that folks will admire.
