Prototype Bluefin 12; 12' fishing SOT
First entry for build of prototype Bluefin 12; a 12' fishing SOT. Below is a high level drawing from Matt.
I finally found some time to work on this project. Terrible how work and family activities get in the way of a perfectly good boat build!
All pieces have been cut from the plywood based on Matt's great instructions. My last build, the tandem, was done from Matt's CNC cut kit. I have discovered that I am not the shop-god that Mick is! My cuts are not terribly straight/precise. Little did I know how spoiled I was by Matt's computer precision cuts! So if you can afford the kit/shipping and aren't a purist that feels a kit degrades your "self-built" monicor, I'd definately recommend Matt's kits!
As you can see from the photos below, I've spliced the hull panels, assembled the cockpit frame, and stitched the cockpit together. I'll fillet the cockpit over the next several days.
Hull panels spliced
Cockpit stitched
Hull panels spliced
Cockpit stitched
