Closing up hull Stern and Bow ends
Mullet_Key
Post by Mullet_Key »
I've been using this little trick to close up the Stern and Bow ends, especially the bottom-most hull panels that have some complex bending to go through to come together.
I cut some 3/8" dowels, about 3/4 to 1" long. Cut a short groove to help hold the wire in place. (one on the backside of the loop and 2 very shallows ones on the twist ends of the wire) Drill 2 holes in each panel about 1/2 apart where I want the hulls to pull in closer.
Wire the holes, going around the dowels. It's best to pull the panels in by hand a little when tightning up the wire twist so you won't break the wire. If the wood is being strained, give it rest, work on the other end or somewhere else before coming back to it. Use regular stitches on the end to help hold it tight as you bring the panels closer.
I should add that both wires run through drilled holes. None of the wires should be outside the edge of the plywood. I think the dowels would roll off if that was the case.
Diagram in Matt's message below.
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
If you want, send me the file and I'll post it up for everyone to download.
Post by Kayak Jack »
Yeah, I'd like to see a picture or a sketch. The verbal leaves several possibilities for configuration. Sure as hell I'll pick the wrong one!
Heya MK,
That sounds like a real good idea mate. I would be real keen to have a look at the piccies too please.
Clever. Not as complicated as a bra, and it holds'em up nice.
Mullet_Key
skip
Clarification added in last line in first post
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
Heya, MK Great idea mate. Thank you for sharing.
LEE SCHNEIDERMANN
Post by LEE SCHNEIDERMANN »
I can see that matt did the drawing...colors are all inside the line and everything!
