Here's my creation for a tiller extension.
Using 2" pvc, cut 2 slashes into the end of the pipes, and sand them round. Mine are 12" long. Wallaaah you have fishing pole holders.
Don't want a fishing pole holder? OK OK lets move fwd.
This picture is pretty self explanatory. Drill holes through the end of the now rounded off PVC pipes. Take a much smaller piece of pipe and drill holes through on both ends. Run small bolts through both pieces as shown. (note, I used small nuts as spacers between the inner and outer pieces of pipe so that it would stay centered)
On the other end of one of your pieces, make a long cut into both sides like shown. (dont use a sawzall or it will look messy like mine.
Cut a longer piece of pvc or broom handle or whatever you might have laying around and slip it inside the other end of your PVC. Drill a hole through both pieces of material and run a small bolt through. Thats it, you have a tiller extension.
And I have some movies of how it works. they are all around about 7 meg So they may be long downloads for those of you on dialup.
Movie1
Movie2
