and have a few questions...
1. Regarding the frames--I didn't see them sketched out on the plywood panels in the plans, are the frames just supposed to come from scrap plywood--or is another sheet required? Also, is there a minimum thickness required for the frames (to be more stable during assembly), or should it be about the same as that used on the hull?
2. There are three options listed, which refer to using less thick plywood depending on how much fiberglassing is being done--1/4" (6mm) vs. 3/16" (4mm). I was planning on glassing the entire hull--but I'm not sure if I can find 4mm ply--how much difference will it make on the 15.5 foot Iroquois if I use the 1/4" ply and glass the whole thing? I'm assuming it's a weight issue--how much difference are we talking?
