3m fiberglass resin
jaa22
Type of boat I like: Laker14
3m fiberglass resin
Post by jaa22 »
Just starting my laker 14 and went to purchase supplies today. I came across some 3M brand fiberglass resin with hardener at Lowes. Can this be used to make the filets and for the fiberglassing? Is it different than epoxy resin?
Re: 3m fiberglass resin
Post by OnkaBob »
Sounds like it is polyester resin - if it doesn't say epoxy on the container then it is almost definitely polyester. People have built boats with it - tx river rat is one I think - but I don't know of anyone who has tried epoxy and then gone back to polyester. It doesn't stick as well, it contains stinky solvents and it is not much cheaper these days.
Enjoy the Laker build.
Poly doesn't bond as well as epoxy.
If you're buying it from Lowes, calculate the cost per ounce and then do the same for epoxy if you order it through one of our recommended vendors: http://www.jemwatercraft.com/materials.php
Price might not be that far off.
jaa22
Post by jaa22 »
Okay you sold me....I am going with epoxy. Don't want to take any shortcuts, especially with my first build.
Next question....I purchased 4 x 8 panels, but when I used my drywall square to start drawing reference lines, I ended up just shy of 12 inches from the last reference line and the end. Does this matter (the plans indicate that the size is very important).
Thanks!
Jim
Post by tx river rat »
I have built several boats with poly , and for just one reason it was about a 1/3 the price of epoxy and I had a lot of experience working it.
Now epoxy is just as cheap or maybe with what you use in volume cheaper.
jaa22 wrote:Okay you sold me....I am going with epoxy. Don't want to take any shortcuts, especially with my first build.
Thanks!
Jim
How shy is "just" shy?
jaa22
Post by jaa22 »
Thanks!
Jim
2-2.5mm off....
Just add that much to any dimension referenced from the "shy" side of the panel. I avoid nesting panels against the edges for that very reason.
jaa22
Post by jaa22 »
jem wrote:Just add that much to any dimension referenced from the "shy" side of the panel. I avoid nesting panels against the edges for that very reason.
Don't want to sound ignorant, but what do you mean "add that much to any dimension referenced from..."?
Whoops. Meant to say "deduct" that amount.
Look on Panel 1.1. The top 2 dimensions off the right side of the panel are 2.5 and 2.6. Make them 2.3 and 2.4.
Make sense?
