The deck design
toolman
The deck design
Post by toolman »
ImageImageImageI've installed a hatch in the rear deck.I also used waterbase stain and must wait 72hrs. before I can glass it ,waiting again!
Manjimike
Re: The deck design
Post by Manjimike »
Looks beautiful.
Did the wood have a clear coat before applying the stain?, if not how did you stop the stain from spreading outside your lines?
Cheers
Mike
Re: The deck design
Great detail!
toolman
Re: The deck design
Post by toolman »
I used duct tape instead of mascking tape.Also when I cut it out with an exacto knife you leave a small cut mark and the stain doesn't go past it.
Manjimike
Re: The deck design
Post by Manjimike »
Thanks Toolman
PiratePete
Re: The deck design
Post by PiratePete »
Your not the only one who can't wait Terry. I think we all are in the same boat & want so see how that looks once its covered in glass & wet out. . . . Magic. .
Earvin
Type of boat I like: Okwata.
Re: The deck design
Post by Earvin »
Nice :) .
Simon
toolman
Re: The deck design
Post by toolman »
The next wait period once its done is for spring .Hope the wife likes it it's her Christmas gift.
toolman
Re: The deck design
Post by toolman »
Manjimike wrote:Looks beautiful.
Cheers
Mike
Also Mike when I cut out the design I used a paint roller to make sure the tape was down firm.There was a coupe of small bleed through spots so because the stipe area was so small I clued 220 grid sand paper to a ton que depressor and was able to use the thin edge to sand it out. :)
woodman
Re: The deck design
Post by woodman »
toolman wrote:I used duct tape instead of mascking tape.Also when I cut it out with an exacto knife you leave a small cut mark and the stain doesn't go past it.
That is a good trick to know..makes sense ..thanks
