Do I need a thwart on my tv 29
jackjama
Type of boat I like: pirogue tv
Post by jackjama »
My tv 15-29 has a36 inch rear deck and a 50 inch front deck. That leaves about 82 inches unsupported through the seating area. I am thinking that 82 inches is a little too much of a span to leave without a thwart? In fact I am not sure if I might need two.
Gunwales and inwales are 1 inch by 1/4 inch thick each.
I could put one thwart some where in front of me as I am sitting. An additional thwart could go directly behind my seat if needed. Using one thwart would leave open spans of 48 inches and 34 inches. Two thwarts would leave a maximum span of 34 inches.
What do you think? Should I go with zero, one or two thwarts?
Jackjama
Freedom 17
Pirogue TV 15-29 in progress
Re: Do I need a thwart on my tv 29
one should be plenty. If you deck supports are stout and you have the prescribed thickness gunwales, you could skip the thwart. But it makes a handy spot to grab onto when needed.
jackjama
Post by jackjama »
Thanks. I am also put handles on the sides and the thwart will straddle the handles stiffening things up a bit.
Jackjama
Freedom 17
augh.... good idea.
Post by tx river rat »
The opening on my Northwind is that big. No problem and I have seen a couple open top T_V that had no thwarts. with no problem
woodman
Post by woodman »
I have short decks and stiff gunwales, works great, tip it on the side to drain and the water runs through the slots...
viewtopic.php?f=8&t=3403
