Fishfinder battery
lncc63
Fishfinder battery
Where would it be best to make or attach a battery compartment for my fishfinder? Should it be watertight? The battery is 12v.
Louis
Hi Louis,
I use a small, closed cell motorcycle battery. Only weighs about a kilo or so and just put it somewhere out of the way.
BTW, I have also used a 12 volt battery drill battery and that works very well.
lncc63
Thanks guys, so I guess that means no special considerations.
You got me thinking Mick. I had a 12-volt motorcycle battery in my mind also. However now that you mention it, 12-volt power tool batteries (NiCd) would do much better because they are built for what is called "deep discharge" whereas the motorcycle (car) batteries don't like being discharged. On the other hand, Cd in the water is NOT a good idea. Think tupperware!
Louis
If you aren't using a sealed battery then I would suggest some form of ventilation for the case or it might get explosive from the fumes discharged from the battery when you open the container near a spark.
Chuck
Chuck
Mullet_Key
Hi MK,
I cut the positice power wire and inserted an inline fuse holder.
I crimped a spade terminal on he end of each wire leading to the terminal and, being careful to align the positive wire with the positive outlet of the battery held them in place with one of the plasticspring clamps I use to build my boats.
Some power tool batteries connections have a gap between the connection points and the battery body. On these, the spade bits can simply be inserted into the caps
I will try to get a piccie or two tomorrow mate.
Mullet_Key
