There are not many outboards available where I live, well at least ones I can afford. So when an 8HP came along I snatched it up.
My question is what do I need to do to be able to use this safely on the Muskoka? Do I need to reinforce the transom? Would it be safe to operate? If I remember right, 2 hp will get the Muskoka to hull speed.
Thanks in advance.
"Big" motor on a Muskoka
lncc63
Louis
lncc63
"Governing switch" - will do that.
I could do the breasthooks but I'd have to cutout part of the pretty inwale
. How about I add another 9mm to the transom and laminate 2 pieces of 6mm ply to the inside of the tumblehome panels from the lower side of the inwales to the deck which is about 4" to 6" from the top of the transom? If this won't do then how about if I raise the deck (9mm) to the level of the sheer and put a well for the motor clamp. I know this is a lot of work but hey it is all fun to me
Thanks Matt.
Thanks Matt.
Louis
lncc63
Just goes to show how inexperienced I am at all of this ... after seeing the actual motor and putting it on the transom, I can see clearly what you guys have been saying. Unless Matt says "do this .. and do that and it will work", its time to find another way.
I know this is beyond any tech support obligation but I'm hoping someone can point me in the right direction. Actually, I'm building 2 Muskokas. The panels for the second one are already cut and ready for assembly. I've of course thought of joining them into a very stable catamaran of sorts for all-the-family outings. My question is any suggestions on how I should link the two hull so I can use the motor on this?
Louis
