New guy here but long time boat builder. Just ordered plans from Matt for the Freedom 13.
Question is if I make the hull out of Okoume ply and the deck out of the darker brown Meranti in the same thickness any idea how much weight increase I would pick up?
Okoume is supposed to weigh 13 lbs for a sheet and Meranti about19 lbs per sheet. I really like the clear finished look of Meranti over the light brown of Okoume ply but don't want to pick up to much weight increase...Thanks guys.
Freedom 13 plywood weight..
Re: Freedom 13 plywood weight..
If it's 4mm, about 4 pounds more.
If it's 3mm, about 3 pounds more.
Both assume you're including the coaming.
Thanks much Matt, that's about what I thought. Got the plans from you this afternoon, nice work and great detail. I have build a lot of boats from plans and yours would rate at the top of the list for quality, once again nice work!...
